What is the best process to complete this design?
I am trying to make an assembly of this stove box:
It is constructed with sheet metal and rebar. The inside of the box is hollow which allows smoke from a fire below to be forced into the opening you see in the cylinder and out the back opening of the rectangular box.
I have some OnShape experience but not with anything hollow like this so I welcome any advice on next steps. This document is my design so far. I am wondering what is the best method to make a rectangular cut in the face of the cylinder and the best approach to adding the rebar shown here in the photo.
https://cad.onshape.com/documents/d681eacb63c592a67ca6b525/w/1c6de8cf5cabc563584d7c40/e/6368e1bb19ecb2f249cb1b63
Then, if you click the sheet metal tab, you'll get flattened parts with the right dimensions:
You can add the rebar with Neil Cooke's beam feature using the custom profile option, with a circle for your rebar's size in another part studio:
https://cad.onshape.com/documents/e15c2c668d138f01242d0c80/v/9c3d422daa69798c999d2076/e/2d5660fc1012df9598f00251
Hope this helps!
I see that you added a hole to the cylinder. Can you explain how you made it? I need to move it to the other side of the cylinder and resize it.
Then, in Split 1, I split that face, making two new ones that can be selected individually.
Finally, in the sheet metal model, I only pick the face I want to convert.
Please let me know if you have any other questions! Also, feel free to make a copy of the document so that you can investigate the details of it!
(it's a good idea to fully define your sketches, so don't leave them blue like I did!)
