SELF INTERSECTING ERROR ON LOFT WITH 3 POINT ACR AS GUIDE PATH
Alyx_Clark
Member Posts: 5 ✭
As the title says, I'm trying to loft between two faces using a 3 point arc as a guide to add curvature to the loft. Link is attached. Any help is appreciated. Thanks.
https://cad.onshape.com/documents/e23016fdb4a673a18bc2463a/w/676cd48d2b3dce8d2f641fda/e/6409807c8957bbeab643f408
MichaelPascoe
Member Posts: 2,814 PRO
In that case, try something like this:- Split the faces you are trying to loft (This way there is not a shared vertex which can cause problems in a loft)
- Loft New the two faces, select normal to profile for both end conditions
- Loft Add the remaining two faces with guide curves (Note: guide curves must be exactly connected to the vertices they are connecting)
RENDERCAD
________________________________________________________________________1
Here is one approach you could take: Instead of trying to loft a complicated corner, start the model off by creating a simple Sweep. Note that the corners of my sweep path are filleted to ensure the rounded corners.
https://cad.onshape.com/documents/63ecca5449c15af7d23e1975/w/f885ed38879488d7f7bccf38/e/e0445440a53a4fcb1237bdf3
RENDERCAD
https://cad.onshape.com/documents/63ecca5449c15af7d23e1975/w/2080e9fd2b5ad1a4b48ff70c/e/e0445440a53a4fcb1237bdf3RENDERCAD
