Feature Request - Company constant Library & standards
WRegnaud
Member Posts: 5 PRO
Global constant library.
We are a company that uses similar constant across multiple projects. Most of them are tied to standards like sheet metal gauge, wire size and tool radius.
A constant library would help standardize our designs and reduce design review time and errors. I see this feature as the translation of libraries we already use in google sheet. Categories with all constant relevant to this standard that can be accessed in using the # just like a local variable.
Thoughts?
Thoughts?
I made this tutorial video about how we do it at Ovyl. It uses featurescript, but I walk you through step by step and once you get it, it's very simple to use.
