shared predicate definition with slight differences
EvanReese
Member, Mentor Posts: 2,856 PRO
I'm trying to get between. In this case, I'm trying to write one predicate for my Cone and Prism features. The only difference between them is the definition.sides number for the prism. How can I write this only once, and hide that field on the Cone feature but show it on Prism? Link below to see what I'm trying to do.
https://cad.onshape.com/documents/a81f647d405a78c5b70bdbde/w/cb4099ea5a4f73db91ad5b5b/e/b82bd38a9390b4dd3155b161
chadstoltzfus
Member, Developers, csevp Posts: 168 PRO
It looks like you went for sending an "isPrism" argument to the predicate, which should work. You could also set a key/value pair in the precondition of Prism feature and have the predicate do a check to see if that key is defined in the definition map.Applications Developer at Premier Custom Built
chadstoltzfus@premiercb.com0
Here's what I ended up doing which worked, but I'm guessing there's a cleaner way.
in both preconditions (Cone and Prism) I added this:
annotation { "Name" : "isPrism", "UIHint" : UIHint.ALWAYS_HIDDEN, "Default" : true } definition.isPrism is boolean; twoEndedPrimitivePredicate(definition);With the default set true in Prism and false in Cone. Then I made the "sides" field conditionally visible withThe Onsherpa | Reach peak Onshape productivity
When I say key/value pair in the precondition I really mean another parameter. As you're probably aware, a feature definition is nothing more than a map, and maps consist consist of key/value pairs. Ex:
var definition = { "key" : value };So in this specific use case the key/value pair being used is "isPrism"/true.In my mind when dealing with predicates talking about a definition more like a map than a UI element makes sense because predicates are a more granular level of what the precondition (UI code block) of a custom feature entails.
