Can I tell if a part property has already been set?
EvanReeseEvanReese Member, Mentor Posts: 2,869 PRO
If a part property has been manually set, it can't be set by FeatureScript. I'm wanting to write a general-use function that can be used by any property-setting feature which can tell whether it's worked or not, and provide a message with instructions on re-setting properties if not. Seems like getProperty can't be used in the main feature function. I tried using it in editing logic, but even if the main function sets the name, it still only returns the pre-feature name. Can this be done? It seems like it could be useful to lots of people writing features, not just me.
Here's what I've tried so far: https://cad.onshape.com/documents/87f7a0c59449e08d9aa23e09/w/0badf39844ddae5eda7380ea/e/6258d6bf25bd8fed2b987dcd
  • lanalana Onshape Employees Posts: 762 image
    Unfortunately, we don't know at the time of regeneration if setProperty would have the desired effect. a. A later feature might override that property, b. Interactively assigned properties are always applied at the end of regeneration.
    So it is really a question about the future.
    getProperty() was supposed to work only in the custom tables, it's not working in features. Probably we could have at least an exception of setProperty() if it fails to reset the property or returned value of boolean type indicating completion status.
  • EvanReeseEvanReese Member, Mentor Posts: 2,869 PRO
    Do you know of a way to tell whether setProperty() has worked? That's really all I'm looking for. Or are you saying it would be nice if the devs added that to the setProperty() function?
    Yes, I wanted to say that I have no idea how to find out this execution status of setProperty(), sorry.
    Got it. Well if you're not sure I'll probably table it for now.
    Thanks, Lana
