Extrude from lines or Offset line from center; Architectural drafting
PieceyPiecey Member Posts: 6
I'm trying to sketch a house for visualization purposes and wasn't able to find an easy way to lay out a floor plan to create walls for a structure. I can't remember which CAD programs had these features but being able to either 1) extrude a certain height wall from sketched lines vs completed faces or 2) offset a sketch from center for easier floor plans.
https://cad.onshape.com/documents/51c2ee4e36b67b50de2b58de/w/dafaeb0f7bad3cd27d6dea2f/e/70fa7ca421c86e5ad7cf05d6
I'm a former SW user and just jumping back into solid modeling after a long time and am ecstatic to have such a robust solid modeling in browser form to play with!
Alternatively, how are others sketching buildings? Perhaps there's a better workflow especially when creating all the components that go into a building.
    steve_shubinsteve_shubin Member Posts: 1,069 ✭✭✭✭
    edited September 2021
    @Piecey
    extrude a certain height wall from sketched lines …
    There are a few different Extrude FeatureScripts that you can install that have Thin-feature
    For components —
    Various manufacturers either have 3D models or 2D DXF’s or DWG’s.
    You can go online and download models such as in the SAT format, or download 2D DXF’s or DWG‘s and make a model from the 2D plan.
    @Piecey
    Also — the extrude featurescript above allows you to place the wall on either side of the line, and it also lets you center the wall on the line.
    That looks pretty handy! Is it a paid feature?
    I can't seem to find that in the featurescripts I've come across so far.
    MichaelPascoeMichaelPascoe Member Posts: 1,735 PRO
    Extrude is free in Onshape. Onshape is free if you are using it for hobby purposes. If you are using it for business purposes, you will need to purchase a pro subscription. Here is the best place to learn how to use all of these neat Onshape features: Onshape Learning Center
    What @steve_shubin said is good, the extrude feature will work great for extruding some simple walls. It's located at the top left of your screen when inside a part studio or at the top right there is a search bar you can use.
    If you would like more detailed walls or have several rooms with different wall profiles, I recommend using the custom feature Pattern & sweep for walls and panels. To add this to your tool bar, click the link and follow the instructions.
    Here is my workflow for rooms, trim, and panels, you can follow the Pattern & sweep link to see see this workflow in Onshape:
    • Create your variables that you can use later
    • Sketch the floor plan
    • Sketch the wall profile
    • "Pattern and sweep" the walls with my custom feature
    CADSharp  -  We make custom features and integrated Onshape apps!   cadsharp.com/featurescripts 💎
    You will find it in the document below
    https://cad.onshape.com/documents/d86ccadb2e501bb1c1e01257/w/80fd84b75cff0425444a7528/e/fb173919842303349e952269
    And here is how to install a custom feature
    https://cad.onshape.com/help/Content/customfeature.htm
    @Piecey
    Here’s a GIF showing how to add the two features above
    @steve_shubin
    Ah, the extrude you were showing was a custom feature. That does look pretty useful.
    @MichaelPascoe
    Not anywhere as fancy as your feature. But for somebody that’s just getting up to speed with Onshape, it might be a little faster to get going with
    NICE GIF Michael !!!
    david_lang457david_lang457 Member Posts: 72 ✭✭
    @steve_shubin
    that thin-feature makes it very convienient to create any sort of boxes from a top plan. Are you aware of anything that can take the result and turn it into panels?
    In an ideal world, you could make the panels overlap so that you could then use the box joint featurescript to make tab connections between the walls and then the auto-arrange featurescript could lay them out for easy lasercutting
    That would make it very easy to create a building in onshape, and then turn it into a model
