CAD file scaled for use in drawing 3D model
in Drawings
I recieve CAD files out of AutoCAD from my CAD person.
The files show a group of different views of locomotives I model.
I would like to be able to scale the CAD files so that the entire group sizes correctly.
Then take each indivitual component and place it into it's own file to model separately.
Can someone explain how the above workflow could happen at Onshape?
Thanks
Thanks
Here is one way to do this:
- Import the dxf or dwg files into your onshape "document".
- Create a part studio.
- Inside the part studio, create a sketch.
- While inside your sketch, insert the imported image. (I recommend using this as a reference only. Create a separate sketch for your modeling. One that is properly constrained. See the Onshape learning center for the best way to learn Onshape)
- Once your image has been inserted, while inside your sketch, place one dimension with the dimension tool, the entire sketch will scale accordingly.
- You can then create part studios and new sketches and either copy/paste the portions of the main sketch that you need or derive the entire main sketch into the other part studio.
Note that Onshape has trouble using large file size dxf or dwg files.Importing and scaling a dxf
In that case, I tried copying and pasting unto a sketch in my Part Studio, but it seemed a bit hung up there also.
Any suggestions to a better workaround?
Something that may work is to "crop" the dxf to one train view at a time so that there are less lines. You will need to find some other dxf editing software to do that.
Another alternative is to capture a high quality screen shot of it. Then insert the picture into onshape and trace that. This is the approach I would take. I use it for tracing trim profiles.
But I'm using CAD files so that I can snap to points for 3D modeling. So the tracing idea really won't work for me.
It's interesting, when I copy all the lines and points for one area of the orignal CAD drawing, and then copy it, I find I can only paste it into a drawing. But then the drawing becomes a picture of the copyed area, with points and lines, but can't be navigated in. Like zoom or pan or any other navigational way. If I click on the drawing tab, and then export out to a DXF file, import it back into Onshape, I can then insert it into a sketch. Seems like a wonky way to do things.
The original file was done in MM, and my system on Onshape is set for Inches. The also seems to cause issues with sizing.
The plane profiles seem very small for some reason.
That does sound strange. It should not be doing that.
The planes can be resized if you click them then drag the corner manipulator points.
The
Could you clairify your statement please? Would you suggest another format?
