How to model this tapped hole?
René_SartorioRené_Sartorio Member, pcbaevp Posts: 58 PRO
edited October 2021 in Community Support
This is made with SWX
This is Onshape:
I can´t enter 8.01 (at 7.407) without other values changing.
How to work correctly with %diametric engagement?
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 580 image
    @René_Sartorio  I created a ticket for you and tied you to a needed improvement in the hole feature.  For everyone else reading this thread...
    Yes, we need to improve this to let you choose which two parameters out of the 3 are driving - just like our chamfer tool.  Currently the thread clearance parameter is not a driven parameter.  For now, you'll have to back into what you want by adjusting the thread clearance parameter.  We do support non-integer values in the inputs.
