Duplicate feature parameter's'
Toshimichi_OdaToshimichi_Oda OS Professional Posts: 53 PRO
Error occurred, but I do not think it is not an error.
I use duplicated name of inner parameter of array, but names of two arrays are different.
It is not serious for me because I am good to change the name.
annotation { "Feature Type Name" : "My Feature" }
export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        annotation { "Name" : "Widgets", "Item name" : "Widget", "Item label template" : "#myParameter" }
        definition.myWidgets is array;
        for (var widget in definition.myWidgets)
            widget.arrayItem is string;
        definition.myWidgets2 is array;
        for (var widget in definition.myWidgets2)
            widget.arrayItem is string;  // when change to "widget.arrayItem2", no error
Maybe namespace of each item of array is not exist .
    lanalana Onshape Employees Posts: 697
    @Toshimichi_Oda
    This sounds like na error on our side. Thank you for pointing it out.
    Thank you.
    I feel good about usability of FS.
    Alex_KempenAlex_Kempen Member Posts: 244 EDU
    @lana Is this actually a bug on Onshape's end? I always assumed it was just a part of strict unique parameter naming requirements, as described via the last line of the documentation on array parameters:
    Note that inner parameter names must be unique across the entire feature (even though they are not stored directly on the definition map).
    CS Student at UT Dallas
    Alex.Kempen@utdallas.edu
    Check out my FeatureScripts here:
    ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,178
    @Alex_Kempen
    Yes, this is more of a known limitation than an outright bug.
    @lana , @ilya_baran, thank you.
    I see it is a limitation than an outright bug.
    The limitation is a little hassle only in programming,
    but no problem for using feature written in FS.
    So I think it is not serious.
    On second thought, it is strange for programming.
    In precondition, I make the same two preconditions to be made to a function.
    One is out of array, another is with in array-loop.
    annotation { "Feature Type Name" : "testCallPredicate1" }
    export const testCallPredicate1 = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            stringPredicate1(definition);  //out of array
    annotation { "Feature Type Name" : "testCallPredicate3" }
    export const testCallPredicate3 = defineFeature(function(context is Context, id is Id, definition is map)
    precondition{}
    annotation { "Feature Type Name" : "testCallPredicate2" }
    export const testCallPredicate2 = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "Widgets", "Item name" : "Widget", "Item label template" : "#str" }
                stringPredicate1(widget);  // within array-loop  // Error!
                // stringPredicate2(widget);  // no error!
    predicate stringPredicate1(definition)
        annotation { "Name" : "str" }
        definition.str is string;
    predicate stringPredicate2(widget)
        widget.str is string;
    stringPredicate1(widget) causes Error.
    But stringPredicate2(widget)  has no error.
    And using 'definition' instead of 'widget' has no error.
            for (var definition in definition.myWidgets)
                stringPredicate1(definition);  // no error!
    I think that it is strange for program.
