trying to model the ball path for a ball screw
david_lang457david_lang457 Member Posts: 103 ✭✭✭
This is a helix where at the end of the helix, there is a tunnel through the body to the other end of the helix. I'm stuck on how to join the ends of the helix, directing the path into the cylinder, then towards the other end of the helix, then back out of the cylinder (all of these through a reasonably gradual curve that the balls have a chance of following
