Loft ?
alison_gray769
Member Posts: 9 ✭
I am a recent user of Onshape and learning about the sketching features , but had a problem using the "loft" feature attempting to bridge over two geometric entities to get a smooth surface
curvature. I used the bridging and projected curve features to create loft guides. I would appreciate any suggestions as to how to proceed. Thanks
Optionssteve_shubin Member Posts: 1,068 ✭✭✭✭@alison_gray769
is this what you were looking for ?
I used those two curves as PROFILES and NOT as guides. See the picture at the bottom of this post0 -
Optionssteve_shubin Member Posts: 1,068 ✭✭✭✭@alison_gray769By the way, it is possible to use the edges of parts to make a loft.
In this GIF, I did not select either of the curves
This time I tapped on the edges of the parts to use as profiles for the loft
https://cad.onshape.com/documents/52fada1a7504bd0e82de5cd2/w/b6f854dbe230995041249519/e/e9be88e66c6f3729f6e111e3
Mr. NeilCooke here is the diagram of the two geometric entinties I tried to loft (Surface curvature ) between.
