Datum Flags don't follow ASME Y14.5M
S1monS1mon Member Posts: 3,949 PRO
edited October 2021 in Product Feedback
I'm just starting to play with drawings, so maybe I'm missing something, but a couple things with datum flags are jumping out at me:
I should be able to add a flag to a linear dimension like this to indicate that I want a datum at the center of the feature dimensioned by the 4.3. I would expect the flag and triangle to replace the arrow on that side of the extension line. Instead I get this messy behavior:
Here's the standard:
I can get it to do what's shown here with 🄰 in figure 3-4 (a), but I can't do the same as what's shown with 🅂 or 🄲.
I should be able to add a flag to a diameter dimension extension line like it shows in figure 3-4 (d).
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 567 image
    @S1mon I created a support ticket for this.  We should have an improvement that covers this case.
  • S1monS1mon Member Posts: 3,949 PRO
    @PeteYodis
    Thanks for creating the ticket.
  • dgodfreydgodfrey Member Posts: 1
    @PeteYodis for case (d) in the image above as well?
    edited October 2021
    @dgodfrey I created a ticket for you as well.    Case d is a separate improvement planned for radius and diameter dimension cases, as well as hole callouts.  The work around for now is to attach directly to the edge in the view  - which is a valid method as well, but just not as compact.
