How do i trim a portion of text?
rodger_ebertrodger_ebert Member Posts: 2 EDU
    best to share a public document; see instructions here
    In meantime some generic ideas: good chance you can use direct editing tools or a standard tool like extrude or revolve with add selected.
    www.accuratepattern.com
  • lauren_bairdlauren_baird Member Posts: 5 EDU
    Any feedback on this topic? I assumed the text were lines...but it seems as though I you can only trim the entire letter and not just a piece of it...
    It's not quite clear what you're trying to do, but you might try this: create one sketch with your text, then create a second sketch and pick just the lines you want to use with the "use" tool so that you can do what you want with the lines.
      I can't trim the parts of the B that overlap into the circles. I'm trying to make a quick keychain to 3D print as an example for my class.
  • S1monS1mon Member Posts: 4,188 PRO
    While you can't trim the text in the same sketch, you can choose the regions to extrude easily.
    You can also make a second sketch, and use the sketch with the text as references to make whatever geometric modifications you want - I added the rectangle at the top and used the trim command to make that shape:
