Adding a cover to one end of a cylinder.. (Edited for one end.)
BigJerrBigJerr Member Posts: 9
edited November 2021 in Learning Center
Hello everyone. I have just constructed a cylinder in Onshape and was wondering how to put a fabric cover at each open end of the cylinder. TIA.
https://cad.onshape.com/documents/e7b657fa270146613ac1402c/w/71e761a68a041e92a8d04d59/e/865c4aea3b002c9260d3d515
  • KatieHuffmanKatieHuffman Member, Onshape Employees, Developers Posts: 194 image
    @bigjerr_papa
    You created a surface model rather than a solid. If you create a solid the ends will be capped and the model will have volume. Edit the extrude feature and change the option to Solid.
  • BigJerrBigJerr Member Posts: 9
    Thanks. But, I need it as a surface not a solid.
  • MichaelPascoeMichaelPascoe Member Posts: 2,876 PRO
    Do you simply want a flat surface cover or do you want it to actually look like fabric like the pic below?
    RENDERCAD
    Nylon, for use in a passenger airbag. So the AB will be deployed with some form of gas.
    edited December 2021
    Oooops. Sorry I misread your response. Lol. It's fine.
    Here is how to use the fill feature. You could also use Offset face and set it to 0. However, Onshape is not made for surfaces, it works best with parts. Most likely these parts will have thicknesses in real life, so creating them as parts should be fine in this case.
    Also, here is a great place to learn Onshape Learning Center.
    How to use the Fill feature:
    RENDERCAD
    Thank you.
    Thank you. Can there be a thickness to cylinder walls and still attach the end cap?
