Adding a cover to one end of a cylinder.. (Edited for one end.)
BigJerr
Member Posts: 9 ✭
Hello everyone. I have just constructed a cylinder in Onshape and was wondering how to put a fabric cover at each open end of the cylinder. TIA.
https://cad.onshape.com/documents/e7b657fa270146613ac1402c/w/71e761a68a041e92a8d04d59/e/865c4aea3b002c9260d3d515
@bigjerr_papa
You created a surface model rather than a solid. If you create a solid the ends will be capped and the model will have volume. Edit the extrude feature and change the option to Solid.0 -
Thanks. But, I need it as a surface not a solid.0
Do you simply want a flat surface cover or do you want it to actually look like fabric like the pic below?
RENDERCAD
________________________________________________________________________1 -
Nylon, for use in a passenger airbag. So the AB will be deployed with some form of gas.0
Oooops. Sorry I misread your response. Lol. It's fine.tim_hess427 said:0 -
Here is how to use the fill feature. You could also use Offset face and set it to 0. However, Onshape is not made for surfaces, it works best with parts. Most likely these parts will have thicknesses in real life, so creating them as parts should be fine in this case.
Also, here is a great place to learn Onshape Learning Center.
How to use the Fill feature:
RENDERCAD
Thank you.0
Thank you. Can there be a thickness to cylinder walls and still attach the end cap?0
