Adding a cover to one end of a cylinder.. (Edited for one end.)
BigJerr
BigJerr Member Posts: 9 ✭
edited November 2021 in Learning Center
Hello everyone. I have just constructed a cylinder in Onshape and was wondering how to put a fabric cover at each open end of the cylinder. TIA.
https://cad.onshape.com/documents/e7b657fa270146613ac1402c/w/71e761a68a041e92a8d04d59/e/865c4aea3b002c9260d3d515
  • KatieHuffman
    KatieHuffman Member, Onshape Employees, Developers Posts: 194 image
    @bigjerr_papa
    You created a surface model rather than a solid. If you create a solid the ends will be capped and the model will have volume. Edit the extrude feature and change the option to Solid.
  • BigJerr
    Thanks. But, I need it as a surface not a solid.
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,945 PRO
    Do you simply want a flat surface cover or do you want it to actually look like fabric like the pic below?
    RENDERCAD
  • BigJerr
    Nylon, for use in a passenger airbag. So the AB will be deployed with some form of gas.
  • BigJerr
    edited December 2021
    Oooops. Sorry I misread your response. Lol. It's fine.
  • MichaelPascoe
    Here is how to use the fill feature. You could also use Offset face and set it to 0. However, Onshape is not made for surfaces, it works best with parts. Most likely these parts will have thicknesses in real life, so creating them as parts should be fine in this case.
    Also, here is a great place to learn Onshape Learning Center.
    How to use the Fill feature:
    RENDERCAD
  • BigJerr
    Thank you.
  • BigJerr
    Thank you. Can there be a thickness to cylinder walls and still attach the end cap?
