Sheet metal will not work well.
emmanuel_juarez418
Member Posts: 2 EDU
https://cad.onshape.com/documents/2171b4024d7974c24d007af5/w/5d1f891d55390814cd84a23e/e/c867e6e5b79e371722e80c8f?renderMode=0&rightPanel=sheetMetalPanel&uiState=61a7ab6602335e5b08d97e5b
I'm trying to create a sheet metal box and the flat pattern doesn't work or connect together ??? is there any way to fix my problem
lana
Onshape Employees Posts: 761
https://cad.onshape.com/help/Content/sheetmetal.htm Notice5. Select the edges to define bends; edges not selected are made into rips0 -
lana
