Mouse dissapearing in sketch?
My mouse is disappearing only when in a sketch, its only a problem on my current laptop, no where else.
this mouse glitch is making it very hard to create and edit sketches
it shows up everywhere except for the main sketch area
the bug only happens sometimes, going away for minutes at a time and re-appearing with no reason what so ever.
  • wayne_sauderwayne_sauder Member, csevp Posts: 651 PRO
    @Charlie_Bruh
    I have never been able to figure out what causes it, but I use CTRL+Shift+R in a windows machine and the problem goes away.
  • CharlesMcgeeCharlesMcgee Member Posts: 4 EDU
    @Charlie_Bruh
     I'll have to check next Monday, I only go to the build space once a week
    If this works I'll make sure you get the credit you deserve.
