Hole Callout table, change diameter view
matt_anderson178matt_anderson178 Member Posts: 9
Good Morning All,
So I am fairly new to drafting in general, I have moderate experience with Mastercam, but not much with a program like this.
So I am having a problem when I create a drawing and use the hole table and it just shows Ø.197 vs 5mm and the like. Is there a way to make this easier to read for my techs? ( I don't know if they can convert decimal to fractional/metric drill bits)
Thanks.
  • Kira_LeeKira_Lee Member, Developers Posts: 17
  • matt_anderson178matt_anderson178 Member Posts: 9
    Thanks Kira, I was curious if you could do it in a table format as well as callout a #7 drill bit, instead of just converting it to the nearest fraction?
