Where should I ask my beginner's questions?
Member Posts: 175 ✭✭✭
Hello
I am new to OnShape. I have lots of beginners questions (for things that TBH aren't as obvious as they might be!).
Where should I ask my questions?
J
  • Member Posts: 552 ✭✭✭
    In the upper right corner, you find the ?, that's the complete help.
    And the learning center.
  • Member Posts: 175 ✭✭✭
    edited December 2021
    Thank you.
    But my problem is when I still have a number of basic questions where the Learning Center data appears to be incorrect.
    e.g. Right now, I am trying to use my mouse to rotate my part, whilst locking the Z-axis. But holding down Alt does help, however it still allows the user to 'pull the Z-axis of the part towards you'...
    J
  • Member, Developers Posts: 842 EDU
    You can use the arrow keys (15 degree steps or 5 degree with shift-arrow key)  I am not aware of a mouse rotation to keep the plane level as you ask.
    btw you are in the right place for questions. Best practice is to start a new thread for each question.
    I see you have been away from the forum for a while but it is still a friendly active place.  I appreciated reviewing your 'straw poll' from 2016. We have come a long way with Onshape!
    www.accuratepattern.com
    Thanks.
    Out of interest, what are the headlines on this?
    i.e. In what main ways has OnShape moved forwards?
    J
    This only goes back to 2017.    Significant updates every 3 weeks.   https://www.onshape.com/changelog
