UP_TO_NEXT with scope?
EvanReeseEvanReese Member, Mentor Posts: 2,970 PRO
Is there a way to limit the scope of an UP_TO_NEXT endBound in a custom feature? Otherwise it can sometimes behave unintuitively. For example, if the feature is creating multiple extruded bodies using a loop, and the second body runs into the first one.
    I don't think there is any 'official' way to do it. You should be able to approximate it with another way, though, like creating a new context, deriving everything you need, extruding in that context, then deriving the extrude back.
  • EvanReeseEvanReese Member, Mentor Posts: 2,970 PRO
    Thanks! I haven't messed with multiple contexts at all yet, but this sounds like it would do it. Would this incur the same performance costs that the native derive feature does?
    I expect it would (twice!)
