Isometric views in drawings
jason_traudjason_traud Member Posts: 15
Is there a way to control the orientation of the isometric view on a drawing? It seems to be fixed to this orientation. Is there a way to change it to a different corner?
    edited January 2022
    Place the first isometric view on the drawing, then create projected views from the isometric view to get the other orientations. Once you get the one you want, you can just delete the first view.
  • glen_dewsburyglen_dewsbury Member Posts: 1,025 ✭✭✭✭
    You can save a named view in part studio or assembly at any position you like then use named view in drawing.
