How to export Onshape model for use in Simulink using smexportonshape('URL')
I'm getting this error when running the command:
The link then leads to a page with this on it:
"{"message":"Unauthenticated API request", "status":401}"
The Step files are all generated properly but it fails before the XML file is generated. I was also able to run this command successfully using an example from Mathworks so I'm not sure where the issue may lay. Any help is appreciated!
"Error using smexportonshape_implementation
The server returned the status 403 with message "Forbidden" in response to the request to URL
Error in smexportonshape_implementation
Error in smexportonshape (line 38)
xmlFileName = smexportonshape_implementation(url, varargin{:});"
