"Un-splitting" or Rejoining Hole Table
Real quick question: As the subject suggests, is there a method to rejoin a hole table that was split in the wrong place? I had a fairly long hole table and was zoomed out when I split it. I didn't notice it and went about moving some of the hole tags about for clarity, added several dimensions, and then realized I'd like to split in a different row. Can I rejoin the table and then split in a more desirable row? I know I can delete the table and set a new one but that will mean moving the hole tags again. Backing out with undo means I lose the moved hole tags andother dimensions I had added before the table split.
Seems a simple task but I cannot seem to find a solution.
