Problem with piston movement
owen_sabala198
Member Posts: 8 EDU
I'm relatively new to onshape, only used it for school projects but I'm playing around with it to get better. I'm trying to make a simple "engine", but my piston isn't moving right. It stays up straight with the crank and I can't figure out how to get the slider mate to work from block to piston. https://cad.onshape.com/documents/9a6791e07f37f2e9cce1a4c3/w/c6409399f35437b21b183313/e/22aadca81a1c06c0f82d7dc1
https://cad.onshape.com/documents/8d18c2413b9ceb7e65a04443/w/fe990f2eac2313f326bcbb1a/e/c84dc963018c600b270c4649
