Why won't my sweep work on this conical face?
arran_sykes
Member Posts: 4 EDU
My Document: https://cad.onshape.com/documents/2321cbcf0d44b31158ff04ce/w/f2825fa8c885e1939c852d71/e/ad9f99ec1f7e80c9886d86de?renderMode=0&uiState=6212cc1aa595140fd1d168d0 ( Be warned it takes a minute to try and generate a sweep)
I'm trying to construct a thread on a conical face using a helix and the sweep tool. I've been following the solution in the following discussion: https://forum.onshape.com/discussion/4905/trouble-sweeping-a-thread-profile-over-a-tapered-spiral-for-bspt-thread
It still doesn't want to generate and is giving me a boolean error.
My profile is smaller than the thread (0.025"). When I try to generate the sweep it takes a while and when it finally does I can see the whole path in red and it looks fine to me! That's what I want it to do but it won't!
Thanks in advance if anyone is able to help.
John_P_Desilets
Onshape Employees, csevp Posts: 273
@arran_sykes Is this part being 3D printed? If not, it is better to leave the thread model out to increase performance. Instead, note the thread size in a drawing.
Take a look at this approach. I used an offset surface to offset the solid part and extended the offset surface using the move boundary feature.
Next, I applied the helix to the surface not the solid part. This will allow the thread to cut completely through the part after the sweep.
A few things to also consider, a standard thread is 60 degrees and the tool holder holding the cutting insert is perpendicular to the workpiece. (Image below)
Hope this helps. let us know how you make out!
https://cad.onshape.com/documents/5ae9656c2581d894e1fe3e6c/w/3c0b303fd85dc4551f55f5ca/e/bd9af78e3d4ea8f1dced9938
This technique is covered in the learning center for advanced part modeling. Check it out!
Worm Gear Shaft4
Here is a working sample that may help with method.
https://cad.onshape.com/documents/cb2bcd844a298bdf747100bc/w/98472c696ada5bf510cb4476/e/9bc8254b57bd50a9c814793e
Would suggest leaving helix pitch at 1 until all else is completed and verified then reset finer at the end to speed up over all process.
https://cad.onshape.com/documents/7f06ae181f7f81867527e1ba/w/d892968e97e227b11258b2dd/e/b64cff6e625782cfa140c39e
Worm Gear Shaft
The part is being 3D printed since I'm trying to make something that will screw into a circular thread so that when it's screwed in it will clamp down on to a ferrule to hold it in place. I'll hopefully be printing it tomorrow if not next week.
Also, sorry for the delay I've been working on other things the past few days
