Helper Lines in sketch
Manachero_698
Member Posts: 7 ✭
Hi, In Freecad you could create lines that were only for you to help you
in your sketch, but you couldnt create something with this lines.
Does
this also exist in the ipad onshape app? Some Helperlines? Or do you use points with dimensions to create "helper lines"
jose_pedro674
Member Posts: 11 ✭✭
construction lines, they are dashed. Select the line and then tap the construction icon.
1
