Can't extrude properly due to it asking me to select a merge scope.
Valaya_Choudhary
Member Posts: 2 ✭
Trying to extrude those accessory nubs, when I tried it with the New option, the part wasn't sticking together when I was moving it around in my assembly. I am a little confused. Below I have provided two images of my issue. When I select the merge scope as my entire part, I get a small red box at one of the edges of the block.
A more technical reason for this: Onshape does not allow entities to "share" an edge or vertex within the same part.
RENDERCAD
