Import and export STEP files
robert_zschoche
Member Posts: 17 ✭
Did I miss the "STP" file option for import and export?
nav
Member Posts: 258 ✭✭✭✭
Hi @robert_zschoche to import a step file you can do it from the My Documents Page or inside Onshape using the + icon.
It will ask you for some options.
Will take a few seconds and you`ll see your imported parts or assy
ITo Export right click on the Part / Assy Tab and click export:
It will ask you in wich format you want to download the part/assy (Select Step then OK)
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions6
