What's an easier way to sketch concentric closed shapes?
Making concentric circles is easy, but what if you have a more complicated shape, like an irregular polygon? I'm currently sketching concentric shapes by hand, but it's getting old. Any tricks?
This is to make a sort of box, where the walls stay the same width but move in and out as you go up, like a candlestick. I'm currently extruding or lofting each wall section separately. Maybe there's some other way to do that?
https://cad.onshape.com/documents/b1ec68dff06d55ff179d8bc7/w/dc0ae0007b32017045650876/e/3f39a038645434881e565b7e
I used a move face to create the change but you could also use a transform feature to apply x and y scales
You could get creative and use sine function or some other formula to make it more varied.
If you can't easily describe it with an equation, you could just pattern the shape and manually apply different scale features to each section, that would be faster than manually sketching the shape over and over!
EDIT: more details on how this works: https://www.onshape.com/en/resource-center/tech-tips/tech-tip-how-to-use-variables-in-patterns-to-vary-features
When people post questions, sometimes it’s all about trying to interpret, what it is, that they’re trying to accomplish.
Something that stood out in your post was the shape of a candlestick
MAYBE, drawing the shape at the bottom of your box first, and then drawing a profile to sweep around this base shape, well maybe that might accomplish what you’re looking for
Take note that there are two different Part Studios in this document. Look for the two tabs at the lower left
https://cad.onshape.com/documents/fa5f80e8d9466a1a9180b16a/w/2579123d01b71b1064a8589a/e/5333d91e327c42d8b7e1b8acWe
See the document in my post directly above
In Part Studio 2, which is the one I just added, I swept a SURFACE and then THICKENED it to come up with a consistent wall thickness
Here is a section view that shows the wall thickness being the same throughout
