Copying sketches
1) How can I copy multiple sketches together and the paste them?
1) How can I make a copied sketch  indipendent  from the original?
  • robert_scott_jr_robert_scott_jr_ Member Posts: 765 ✭✭✭
    1) Copy each sketch one at a time and paste them one at a time into the sketch you choose.
    2) It will be independent.
  • angelo_scozzarellaangelo_scozzarella Member Posts: 58 EDU
    Thank you. So i can’t copying multiple sketches at once. And if i delete the original sketch all the copies become red, error.
    Hello Angelo. I created a sketch in a part studio and copied it. I pasted the copied sketch into another part studio. I deleted the original sketch. The sketch I copied into the part studio remained intact. There is another reason your copied sketch is in red. However, I would not be able to try to figure it out without seeing your document.
    - Scotty
    Thank you. Using another part studio is a very good advice.
