Changing size of copied sweep
How can I change the diameter of this three copies of a sweep?
    Transform also has Scale command.
    www.accuratepattern.com
  • angelo_scozzarellaangelo_scozzarella Member Posts: 58 EDU
    Thank you for answer, but scale changes all. If i want to change only the diameter of path circle and not the diameter of the section, how can i do it?
  • S1monS1mon Member Posts: 3,988 PRO
    Why not just use revolve in this case? You could revolve 3 circles at once.
    Thank you for answer but i didn’t understand. Would be very useful more details.
    Here's a very simple document which creates the 3 rings in one sketch and one revolve feature. Unless you're likely to change from sweeping on a circular path to some other shape, capturing your design intent with a revolve makes more sense.
    Wow! Thank you! There are a lot of things I don’t know.
