Hope to provide export/import with onshape's own project file format
Pinhe_Du
Member Posts: 2 EDU
The hope is to provide a separate file format that allows the export-import process to fully restore the original project files. Now's exported file formats do not fully recover sketches and variables from the original project file upon re-importing.
I have noticed that onshape has the ability to share links, but I would like to have a fully exported share. The advantage of this is obvious, the exported files are not subject to account restrictions like the shared links, which is a necessary feature if I lose my original account, or if some enterprises do not want to bind administrator accounts but want to have archived files.
I am using the education version now, and I would like to have this function if possible.
Your reply will be appreciated.
