I need help about 2 questions. Mate and Linked Parts.
yunseokyunseok Member Posts: 2 PRO
Hello, I have 2 questions while using onshape.
1. How can i click the mate connector easily which is in the center of slot?
 When i try to click this point, another mate connector is selected automatically.
 How can i select this mate easily? (Not use offset, just click)
2. Can i separate the linked parts(Insert parts) from original parts?
 In assembly tap, I inserted some parts like below. And then, Can I separate these parts from original parts?
 When I modify these linked parts, I don't want to be modified the original parts.
I'm waiting your help. Best regards.
  • S1monS1mon Member Posts: 3,768 PRO
    1. Hold shift after you wake up the face.
    2. Sorry, I don't think I fully understand the context. What do you mean by "linked" parts?
  • steve_shubinsteve_shubin Member Posts: 1,118 ✭✭✭✭
    @yunseok
    maybe this will help you with your question #1
