Onshape exported assembly (STEP) has all parts suppressed by default when I open it with SolidWorks.
I have a large assembly, a few hundreds of small parts. The assembly looks normal on Onshape with nothing suppressed. I exported it as a STEP for others with SolidWorks to review, but SolidWorks has the STEP opened with all parts suppressed. This is not the first time I have seen Onshape STEP assembly suppressed in SolidWorks upon opening.
Is there any solution to have it not suppressed?
You'd probably be better exporting it as a parasolid file (X_T or X_B), possibly at an earlier format version, depending on your version of solidworks
