Pentagon Assembly
jnvillarrealreyes
Member Posts: 4 EDU
I am a student new to OnShape. I am trying to make an assembly of a Dodecahedron by using one part and using it over and over. I get about halfway through until the parts no longer connect. What should I do to complete this shape?
Optionssteve_shubin Member Posts: 1,069 ✭✭✭✭@jnvillarrealreyes
Is this what you are looking for ?
https://cad.onshape.com/documents/5c54e271b889a381812c27da/w/316afef5ce554a2afb1ceb97/e/20536fcedc5f1cab131eb4f8
This above is a new document where the Update Context works properly
1
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
This is what i am trying to do. @steve_shubin yes it is but its only the edges.
https://cad.onshape.com/documents/ad6b96da52e1a35fa926044b/w/c39b5c51a3523b4af8351dac/e/55acf8dde73b7232d22727f1
The angle on the cross-section should be pretty accurate. I modified the document to display this angle
Wow, that's great! Thant you so much, you were a great help!
