Color color color
Is there a way to create a palette with selected colors that i can use in multiple parts? Is there a way to color multiple parts at the same time?
Is there a way for not coloring parts? I use the app on iPad.
eric_pesty Member Posts: 2,338 PRO
You could try using the part color custom feature, which has a some built in color palettes and allows setting multiple parts at once.
https://cad.onshape.com/documents/d997b0ffc30f659113b10c00/v/95371c9f4add91502b3559a3/e/b6db0c9545b9a2df1d7ea546
However there is no simple way I am aware off to create your own custom color palette (other than making your own custom feature, which is not actually that hard but not super convenient...)
Not sure what you meant by "not coloring" parts, they all have to have "some" color, unless you mean transparent?0
