Is it possible to create a Composite Part in an assembly?
gonzalo_chomon
OS Professional Posts: 56 ✭✭
in General
I will like a multi parts assembly to become a composite part.
Is that possible? is there a easy way to do it?
1
A) Export the assembly and import with the option to create a composite part
But if you change the assembly it will not update
I do not like to create more spaces than necessary but...
