Challenges with Origins, Mate Connectors, and Imported Assemblies
If I import an assembly (call it 'A'), and its origin is not located on a part feature, but yet I want to use the origin as a mate reference in another assembly (call it 'B'), what is the best way to do this?
(this happens to be a PCBA that I can't share)
Steps
I'm slowing wrapping my head around how the mates in Onshape work but decades of Pro/E and Solidworks are making this confusing. Especially since so many things that I work on are assembled and don't have a lot of motion. I'm used to dropping in an assembly at a default position and having it not move.
Steps
- Import a STEP from Allegro for a PCBA
- fix one part in assembly A (a connector or some other unlikely to change part)
- group all the parts in assembly A
- add a mate connector (call it 'C') at the origin of A
- create a mate connector in B (call it 'D')
- insert A into B and use a fasten mate between 'C' and 'D'
- drag parts of A around in B
- C and D stay locked together, but because the fix from #1 goes away in B, C just floats relative to the parts from A
I have a very similar issue.
Did you find a solution?
I remember reading about this FeatureScript before. Now I've added it to our toolbar.
(BTW. Your link has an enterprise account in the URL.)
