Can't select helix curve with "Use" command
florent_herbinger
Member Posts: 7 EDU
I'm following @jakeramsley tutorial for creating a spiral (https://forum.onshape.com/discussion/809/spirals); I'm interesting in creating a spiral sketch with a non-zero thickness, and this tutorial gets me most of the way there. However, I'm stuck on step 6, where the helix curve is selected with the "Use" command to project on the sketch below—I'm simply not able to select the helix.
I have outlined my steps here:
1. Make a circle sketch with a 45mm diameter on the Top plane (the sketch plane where I want my spiral sketch to be located)
2. Draw a horizontal construction line going from the center of circle of to its edge (used later for creating another sketch plane)
3. Create a 10mm offset plane from the Top plane (titled "Plane 1") and create a circle sketch with a 10mm diameter
4. Bring the 45mm circle in "Sketch 1" to "Sketch 2" with the "Use" command, and make the center points of the two circles coincident
5. Make the same horizontal construction line on the 10mm circle
6. Make a curve point plane (titled "Plane 2") by selecting the edge of the 10mm circle and the intersection point between the 45mm circle and its horizontal construction line
7. Sketch a line between the 10mm circle and the 45mm circle on "Plane 2"
8. Revolve the line around the 10mm circle as a surface
9. Create a 3-turn helix on the face of the revolved surface
10. Now here is where I am stuck. When I "Edit" Sketch 1 and click the "Use" command, I am not able to select anything outside of Sketch 1, including the helix.
Any help would be much appreciated!
"direction" : Normal.normal * meter,
"axisStart" : CenterPoint,
"startPoint" : StartPoint,
"interval" : [0, table.length*table.TPI],
"clockwise" : true,
"helicalPitch" : table.pitch * inch,
"spiralPitch" : table.Spiralpitch * inch
