SKETCH PLANE PROBLEM
vince_longvince_long Member Posts: 9 ✭✭
I HAVE A SITUATION WHERE I WANT TO SELECT A FACE OF MY SOLID PART AS A SKETCH PLANE BUT MY SYSTEM WILL NOT LET ME SELECT CERTAIN FACES BUT IT DOES OTHERS.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,071 PRO
    Is the face flat?
  • vince_longvince_long Member Posts: 9 ✭✭
    Hi John, yes the faces I want to use as a sketch plane b ut cannot are flat.
  • S1monS1mon Member Posts: 4,165 PRO
    It’s difficult to give general advice without a public document to look at. That said, there’s always a way to get a plane where you want it. Some techniques may require some helper sketches or perhaps using some of the custom feature scripts out there.
    https://cad.onshape.com/documents/0de04acb5bac92ca16796edf
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 6,016 image
    The face must not be flat. You can always use a mate connector.
    is there an easy way to check if a face is flat. #i cannot even highlight the face to measure its surface area. it appears to be under a certain level  that i cannot select faces but above it i can.
    can someone remind me how to upload the model so you all can see it?
    Many thanks for the support.
    Paste the URL here. Plus a pic of which face you are trying to select would be good.
    Is this the URL? https://cad.onshape.com/documents/fda6f52d3426f84b223ce3b9/w/5e11e1d5696b60c530b43349/e/b84370b2a37ce048aa15a628. any of the faces within the area contained by the orange circle are unselectable except for the top of the three round bosses. Also why are they a different shade of grey?
  • wayne_sauderwayne_sauder Member, csevp Posts: 657 PRO
    @vince_long
    You have a lot of sketches showing, the easy way to turn them all off is shift+p.
    You could also use the ~key to select things underneath all your sketches.
    Thanks Wayne, that was my problem.I did not realise that could stop me selecting faces. Every day is a learning day.
