Deleting hisrory or versions
Hello onshapers,
At start of this project I copied workspace from existing document to my document. Than made some changes and also versions. Than I created drawing from this document in other document - because of our company rules.
And now when I want to save it in to our PLM, it holds the link with parrent document from which I copied the workspace.
OK, so I redraw it from scratch in new version, without link to other documents, but when I want to save to PLM, It got link in version 1.
So I need to clear all history and leave only the last version without links.
Please if there is some possibility to solve it, Ill be happy to know.
Thank you :smile:
  • MichaelPascoeMichaelPascoe Member Posts: 2,814 PRO
    The functionality to delete versions has been turned off. It is possible to copy your workspace again now that the changes are made. Once the workspace is copied, there will be no version history in the copied document and you can version it how you like.
    RENDERCAD
