Loft help
alexander_valles
Member Posts: 4 ✭
I'm trying to make a 3D model of the submarine Alicorn from Ace Combat, and when I'm trying to loft these two sections one goes in the direction I want while the other is backwards. Both lofts are identical settings wise, I just have no idea why one is backwards. Loft 1 is basically Loft 2 but in the opposite direction. Again I do not know why it did that while the 2nd Loft did it right.
In my perspective of the picture, it seems that the " Loft 2 " shape isn't the same as " Loft 1 " Shape. There is a way to mirror it to make it identical:
and look up for mirror :
Then select the plane you want to mirror it through so it's identical and flipped. I'm not sure if this is exactly what your problem is but this is a way on how to make your shapes identical so you don't have to take the time to do another version of it. If there is a problem you can let me know! Good Luck! It looks Really Cool! 😄
