LINE ANGLE
michele_vignola278michele_vignola278 Member Posts: 2 EDU
Hi,
How do i a line with angle of 110°, on sketch?
Thanks
    SethFSethF Member Posts: 129 PRO
    edited May 2022
    I would recommend you head over to the Learning Center. There are lots of materials there to get you started with Onshape, whether you're a) new to CAD or just b) new to Onshape specifically and just need a quick guided tour around the toolset.
    steve_shubinsteve_shubin Member Posts: 1,069 ✭✭✭✭
    edited May 2022
    @michele_vignola278
    With the DIMENSION tool ——
    1) Click on the first line
    2) Click on the second line
    3) Enter the angle
    You can also set the angle from a plane to a line
