Is the "Radiate Surface" custom feature redundant now?
alwyn_limalwyn_lim Member Posts: 57 ✭✭
Doesn't the OS built-in "Ruled surface" with 90deg Angle do the same thing?
  • MichaelPascoeMichaelPascoe Member Posts: 2,814 PRO
    I'm not sure if they are the exact same, but they are similar. Radiate surface was created in 2017 by @maximilian_schommer; long before Onshape implemented Ruled surface.
    RENDERCAD
  • S1monS1mon Member Posts: 4,063 PRO
    There are a number of obsolete FeatureScripts out there, including on the recommended list on the Onshape site.
    The one for extending a surface comes to mind.
