How do I add South African Standard Steel Sections
How do I add South African Standard Steel Sections to the Frame Profile Library
  • shawn_crockershawn_crocker Member, OS Professional Posts: 933 PRO
    You need to either find a resource that details the specs of the profiles (like a steel provider), allows downloading them in an appropriate file format(dwg/dxf) or actually measure them and draw them in.  Your profile needs to be in a sketch on the front plane and needs to reside in a versioned document.  Then from the frames tool you can navigate to that document and select the profile sketch.
  • willem_van_der_berghwillem_van_der_bergh Member Posts: 5
    Thank you very much
    Thank you very much.
    How do I add the drawing to the Library.
