Hide 'Disable imprinting' checkbox
Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 266 ✭✭✭
edited May 2022 in General
Imprinting in sketch mode is only relevant if a flat part surface is chosen as the sketch plane. If a plane is selected then the Disable imprinting check box in the sketch panel is of no use.
Can the check box therefore not remain hidden or grayed out in the latter case? Not showing that box also makes the meaning of imprinting more understandable.
