Need help on how to draw this surface.
david_scott949david_scott949 Member Posts: 15 ✭✭
Hi,
I've been struggling for a few days on how to drawn the shape I want.   I need some help.  What I'm after is a dome surface  (revolivng an arc around an axis)
but combine that with a type wave effect around the surface.   Something like this but circular not straight:
I've tried using projected curves but can't seem to make it work.  I'm obviously doing something wrong.
The final result should look something like a umbrella or sunshade.
How would you go about designing that?
