Any work around method to insert radial text in sketch
viruviru Member, Developers Posts: 619 ✭✭✭✭
Hi,
Many products contain the text in radial direction such as round rubber stamps, coins, Ball bearing faces, sheet metal and cast parts etc. So, with the availability of provision of radial text, user can design such parts easily. Can anyone suggest any workaround to insert radial text in Onshape. Below image show the option available in text option of Pro-E.
With warm regards,
viru
    pete_yodispete_yodis OS Professional, Mentor Posts: 666 ✭✭✭
    edited August 2015
    @viru You could place one letter at a time.  One letter, one extrude, then do the next letter.  A series of sketches and extrudes with each letter being on a line that is tangent to the circle..
    Thank you @pete_yodis and @andrew_troup for your suggestion.I gone through both of your suggestion and implemented and find result as shown as below.
    I was thinking same methods earlier today but I thought it's too difficult to update say a part number if written letter by letter.. For logos or such this is decent workaround.
    Text functionality should be improved by following a 2d curve or curved surface or both.
    +1 Ability for text to follow a 2d Curve.
    edited August 2015
     @3dcad
    You're right, it's tedious if all the letters need to be edited. If it's a sequence of part numbers, I guess it's marginally do-able, because only one or two digits would require replacement in many cases. (It's still quicker and easier than engraving part numbers with a toolmaker's pantograph!)
    I guess it's not usually essential that part numbers be 'bent', but if they were:
    I would definitely use viru's method rather than mine in this case, as it would permit sizing the replacement letter simply by snapping. One snap from the midpoint of the baseline to the intersection of the radial line with the base circle, one snap from the midpoint of the topline to the top circle.
    To fix the orientation angle would however still require a (coincident) constraint between the latter midpoint and the radial line.
    I've used sketch text following a curve method many times in SW's. One that comes to mind is a cast hub with part number about the back face, it would be a pain to do it this way but at least now we have text.
