Modeling a hypar shade sail
Hi, trying to model a hyperbolic parabola, the form a piece of fabric takes if you tension it from four points where two diagonal points are higher than the other points. No idea how to start or if this is possible in onshape.
Check this out, this is the low-effort version that you can pretty much scale this up as you wish: https://cad.onshape.com/documents/fc52a198499baa1f098ea16a/w/bbf1663888fe3421b91e1d34/e/625b05eb623b047d48c70857?renderMode=0&uiState=62bb6127f719a30e43837472
But if you know a particular equation you are looking for, you can use this custom feature: https://cad.onshape.com/documents/57a62df8e4b03de4c9fcf154/w/f6d71f3d862b522902efcd68/e/ece65382fcd820281a9ee704
I need a cup of coffee
https://cad.onshape.com/documents/000314657ad47a078765950e/w/73195f16516224d9a9bd42ec/e/eecea850f2e526fb1fb1eaa9
